This procedure only applies to 5520 Series and 5720 Series.
Configure all of the ports on an installed Versatile Interface Module (VIM) to operate at the same speed.
Some VIMs must operate with all ports at the same speed, or a group of ports at the same speed, while others can operate with ports at different speeds. For more information, see Fabric Engine Release Notes. You can configure VIM ports speed only on VIMs that must operate with all ports at the same speed.
Install the VIM before performing this procedure.
It is a best pratice not to use a mix of 10Gbps and 25Gbps VIMs with the auto parameter.Use this procedure to configure the speed of all ports in a multi-port VIM to operate at either 1 Gbps, 10 Gbps, 25 Gbps, or auto.
- Select Chassis.
- Select the VIM tab.
- Select mbps1000, mbps10000, mbps25000, or auto.
- Select Apply.
VIM Field Descriptions
Use the data in the following table to use the VIM tab.
Name | Description |
AdminSpeed Note:
Exception: 1 Gbps port speed applies to 5720-VIM-6YE only. |
The command auto vim-speed is enabled by default. |
GroupSpeed Exception: only applies to 5720-VIM-6YE. |
Configures all ports into two speed setting groups.
Ports in groups must be configured to operate at the same speed. For example, ports 2/1, 2/2, 2/3 can be configured for 10 Gbps, and ports 2/4, 2/5, 2/6 can be configured for 25 Gbps. If 5720-VIM-6YE uses the LRM/MACsec Adapter, you must configure the groups according to the SFP or SFP+ inserted in the Adapter. |
